16’ rafts are ideal for multi-day trips. Here’s a video with some thoughts about the various rafts, frames, and oar combinations to get the conversation started.
Great thoughts! Just have a few clarification questions
Are you recommending that the optimal oar lock position is 4in outside the peak of the tube on a raft?
Also.
Is it also assumed that double rail frames are supposed to straddle the high point of the tube? Can’t you run a double rail frame that has the outer rail over the peak of the tube?
Yes I’m going to say 4-6" outside the peak of the tube. There are 2 main reasons I like this position:
Yes I’ve always seen double rail frames straddle the hight point of the tube. I guess you could have the outer rail on the peak of the tube but I don’t think I’ve ever seen that.
My general suggestion would be to have the oar tower start at the center of the tube or 1-2" outside (away from) the peak of the tube. Most oar towers put the oar lock 3-5" wider than where it starts so that puts the oar lock 4-7" wider than the center.
