Zach, I have a thought that I think will make you roll your eyes, but here goes…
I’m ready to challenge your position that shipping oars blades-forward is the only proper way to ship.
As a smaller guy with a short wingspan, I’ve found that shipping both oars blades forward can create a hazard. I can’t extend the handles far enough to get the shafts parallel with the raft tubes, leaving the blades sticking out at roughly a 20 degree angle. This increases the risk of catching a rock and potentially driving an oar into my gizzards.
Shipping one oar, blade-foward, isn’t an issue because I can lean to that side and extend the handle far enough to get the shaft parallel with the raft. It’s also not an issue to ship both oars with blades forward when I’m rowing a smaller boat since the towers are closer together.
So here’s my question: Is blades-forward always the safest technique, or might a rower’s physical proportions relative to the width of the raft sometimes make blades-backward a better option?
I’m not just trying to poke the bear, I am curious to have your thougths on this. And to be clear, I mostly do ship blades forward, but like the push and pull debate, I think there’s a time for both.
Thanks for all that you do for boaters!
This is a really good question. I’m definitely not rolling my eyes.
The quick answer is that if you need to ship both oars and can’t do it safely, then you shouldn’t. The only other answer is to throw both blades forward so that’s what you need to do.
But…
The vast majority of shipping (99%+) is one oar at a time. Please develop the habit of blade forward shipping when you’re doing one oar at at time.
If you need to ship both oars and can ship blade forward based on your boat size and wingspan then please keep developing that habit. If you can’t, then do the second best option (handles forward).
When I’m teaching classes or watching private boaters I see way too many people throwing their handles forward when they shouldn’t be. In an attempt to reverse that trend I need to be pretty strict about shipping blades forward. You have, however, described the exception that I gloss over in an attempt to be strict. When I row the mid-chute at Blossom Bar I can’t get the blades in enough so I throw my handles forward but that is pretty much the only time I do it.
One more suggestion…Try flipping on oar up on the boat with the blade forward and letting go of the handle and leaning into your other ship. Watch what I do here:
Thanks for that last suggestion and video to illustrate it. Honestly, resting one oar on the boat and holding the other hadn’t occurred to me - smooth.
