Frame bay size preferences
Hey y’all,
I was wondering what your preferences were on rowers bay length and drop hatch length for your multi day setups?
Check out the drawing below of a frame we used for AVON Pros (they may have been a wider version of the PRO). It shows 26" for the cockpit.
The frame and hatches are 72" wide but I’d recommend 66-68" wide if this is for a single rail frame on the SOTAR Praetorian.
I’m a bigger guy at 6’2" and like my captain’s bay somewhere 24-28" long depending on the configuration and room I have on the frame.
I’ve tried my buddies frame with a smaller captains bay, 17" and I ended up smashing my fingers into the cooler in front of me a few times. It was better if I sat way back on the dry box but I still like having more room than less.
I have a drop bag that is 18" long so that’s what I use for a drop hatch length and my table goes over the top to hold everything in.
I have a 16 foot Avon Pro and I spent 50 years designing my frame. Here’s what I came up with:
  • 3 separate pieces; 1 “rowing frame” (2 bays, cooler seat) and 2 separate “drop frames” (simple rectangle with drop bags and table hatch lids). (Basically, Zach’s sketch, but I broke the 3-bay main frame into a 2-bay plus a separate drop. The separate drop is the the 21-inch section that Zach marks for "Boxes_ - not “cooler”, not “cockpit”).
  • “Rowing frame” is a flat (one-plane) rectangle 70 inches wide (c to c of 1.25 inch pipe) and 46 inches* (c to c) fore-to-aft with an adjustable cross bar that can move/slide front or back to accommodate different coolers. For my current cooler, that leaves 24 inches of legroom between the front of the cooler and the forward cross bar.
  • I then have a roughly 18-inch wide "u-shaped’ foot brace that drops down from the front cross bar and is held in place with two Better-Mount frame brackets. I can adjust the angle of that foot brace to move/angle the foot brace towards/closer to the cooler seat if I want to have more leverage or if someone shorter wants to row. It is pretty easy to adjust, so switching from a 6’ to a 5’ rower is quick.
  • My “drop frames” are both 70 inches wide and 18 inches fore-to-aft - my tables sit on top. However, I am trying to design a table that would “nest” inside the drop frame because I think that would be a cleaner look and tie-down. I’m not ready to sacrifice table/counter height (a function of the length of the table), so I’m still musing. Any suggestions welcome - I don’t think I have another 50 years to think about it.
Anyhow, the beauty (in my mind) is that I have a small, minimalist “day frame”, an overnighter (add one of the drops) and an expedition frame (add both drops).
*I would have gone “longer” (more than 46") but the length of the flat, “waterline” portion of my raft is about 88 inches and the frame plus the 2 drops maxes that out. I have a workaround/redo/solution, but it’s complicated and a little janky - I mean “innovative”.
