Here are some guidelines for drowning from the Safety & Rescue Instructor Alliance
These 7 Actions are developed in conjunction of Dr Chris Davis and Dr Stephanie Lareau. SaRIA is hosting a series of Drowning Prevention and Resuscitation Clinics worldwide wide on World Drowning Prevention Day (July 25).
Would you like to host a clinic in your area … find more info here https://www.facebook.com/share/g/1BXJfoiLUc/?mibextid=wwXIfr
What do you instruct/provide/suggest for your guides/students regarding PPE and giving rescue breaths to a subject of drowning?
We have multiple levels of CPR masks on our trips:
- We have all of our guides carry a CPR Face Shield in their PFD
- Each raft has a “boat first aid” that has a better, more rigid face shield
- Each trip (usually in the last boat) has a Seal Rite CPR Mask and Pocket BVM
We annually train with all of these items. In particular the pocket BVM can over-inflate the lungs which can cause problems
Awesome … we do the same… the “real to ideal” is likely
Mouth to Mouth/Nose
Face shield to mouth
Pocket mask to mouth
BVM to Mouth
We supply face shields to our guides to have in their PFDs , have pocket mask in each raft and a BVM on each trip.
Transmission rates of illness is very low (15 cases since CPR was invented) and success rate with early ventilations and high quality CPR is high (10%-17%). When I measure those things I know what choice I would make if I found myself without barrier protection immediately on hand.
Thanks for sharing. If there is no foam or fluids coming from the victim then my guess is that most people would do CPR without a barrier.
Based on my conversation with Dr. Chris Davis, there is generally going to be foam associated with drowning. It’s impossible or nearly impossible to push air through that foam without a CPR barrier so having quick access to a barrier for drowning victims is pretty important.
